S77 Hydraulic fluid capacity??
DEP
08-17-2007 07:48:44
How much hydraulic fluid does a S77 hydraulic unit hold? I put in about 1.5 gallons and I still have nothing showing on my dipstick. I thought it held around 5 quarts? I was at the full level when I got it and after a couple of weeks on the spreader, it was down. I did drain 4 gallons of fluid out the check plug of the rearend.
ejr-IA.
08-17-2007 08:42:34
 Re: S77 Hydraulic fluid capacity?? in reply to DEP, 08-17-2007 07:48:44
You should have 53/4 qt.in the reservoir and 41/2 gallon in the transmission.
DEP
08-17-2007 10:04:45
 Re: S77 Hydraulic fluid capacity?? in reply to ejr-IA., 08-17-2007 08:42:34
Is it possible for the pump to leak internally badly enough so that it leaks into the transmission as fast as you can fill it??
old
08-17-2007 10:35:20
 Re: S77 Hydraulic fluid capacity?? in reply to DEP, 08-17-2007 10:04:45
Yep if the seals on the shaft are bad enough or the pump its self is cracked.
