66 will not idle
man
08-14-2007 06:33:37
i have a 1953 oliver 66 it will run fine on the 4th notch but if you lower it to the third notch it dies
J Schwiebert
08-14-2007 08:22:00
 Re: 66 will not idle in reply to man, 08-14-2007 06:33:37
Warm or cold makes no difference? What happens if before you put it in the third notch if you pull the choke out about 1/3 of the way. You probably have an air leak because of wear maybe on the throttle or choke shafts, intake manifold gaskets go? Do you have a vacuum gauge? J.
rrlund
08-14-2007 13:24:24
 Re: 66 will not idle in reply to J Schwiebert, 08-14-2007 08:22:00
John,I'm wondering if that screw on the side of the throttle plate is screwed out too far where it comes against that pin and it's just trying to idle farther than it's capable of anyway.
man
08-14-2007 14:24:01
 Re: 66 will not idle in reply to rrlund, 08-14-2007 13:24:24
thanks guys i got it to run at an idle (first notch)
