Steering shaft for Super 55
Super 55
08-13-2007 22:05:40
If you click on the photoshare link you can see the bearing assembly that was how my Super 55 gear box was set up. I asked around before and nobody had seen this set up before, but I am going to ask again since that last post was some time ago.
Most steering shafts have a machined surface on the lower end that rides in the thurst bearing. Mine had a beveled race that was pressed onto the shaft that rides in the thrust bearing. When I took my steering box apart the lower bearing was just in pieces so I have no idea if this set up had a different thrust bearing. In the second photo you can see how this would ride in the bearing. Does anyone think this set up will work, or won't work?
oliverdave
08-14-2007 05:11:37
 Re: Steering shaft for Super 55 in reply to Super 55, 08-13-2007 22:05:40
Looks like someone has fixed it in the past with a cone bearing .Should work if you can get it shimed right.
