Oliver 1650 hydraulic pump kit ?
Curtis Gray
08-11-2007 05:16:40
Does anyone know where I can purchase a hydraulic pump kit (seals and gaskets) for an Oliver 1650? Thanks.
El Toro
08-12-2007 07:35:48
 Re: Oliver 1650 hydraulic pump kit ? in reply to Curtis Gray, 08-11-2007 05:16:40
Send an email to [email protected] with the model number you posted. hal
leob
08-11-2007 09:45:53
3302649720 -Agpartsfirst
or
7123242760 - Wes Dorhout
Curtis Gray
08-11-2007 10:29:08
 Re: Oliver 1650 hydraulic pump kit ? in reply to leob, 08-11-2007 09:45:53
Thank you
J Schwiebert
08-11-2007 08:53:43
Well first of all 2 different Cessna and one Vickers hydraulic pumps were used. If you have one of the Cessna pumps and the front seal leaks when you have the pump out carefully measure the wear on the center plate. How strong are your hydraulics? Have you done a pressure or flow test? It might be wise to do that before you take it apart. Gaskets should be available at an Agco dealer, If not I can come up with them. Check your pump before you order a seal kit.
Curtis Gray
08-11-2007 09:11:09
 Re: Oliver 1650 hydraulic pump kit ? in reply to J Schwiebert, 08-11-2007 08:53:43
Im posting this for a friend, so I don't have all of the information. I do know that it is a Cessna pump # J25455RAA. I also know that he has taken the pump apart, and that the seals/gaskets are worn, as it was leaking around the splined shaft. I would like to get him to give you a call. How can I get in touch with you? Thanks for your help.
