Power Steering Pump for an Oliver 550
Bill Werner
08-10-2007 08:36:43
Hi: I am in need of a power steering pump for an Oliver 550 Tractor. If anyone has information where I can purchase one, please give me a call on my cell Phone at 541-410-4180 or drop me an e-mail. Thanks.
J Schwiebert
08-10-2007 13:53:19
 Re: Power Steering Pump for an Oliver 550 in reply to Bill Werner, 08-10-2007 08:36:43
Are you looking for the early pump ( generator driven) or the later pump (belt driven)
Bill Werner
08-10-2007 17:17:32
 Re: Power Steering Pump for an Oliver 550 in reply to J Schwiebert, 08-10-2007 13:53:19
The pump I need is the later style. Separate pump from the Generator style with it's own belt drive.
J Schwiebert
08-11-2007 08:55:49
 Re: Power Steering Pump for an Oliver 550 in reply to Bill Werner, 08-10-2007 17:17:32
Don't laugh but we converted one of the older ones to a belt driven G-M power steering pump. Even used Oliver brackets!. What is the problem with your pump and have you contacted any Cessna pump houses? J.
Bill Werner
08-12-2007 08:13:21
 Re: Power Steering Pump for an Oliver 550 in reply to J Schwiebert, 08-11-2007 08:55:49
My tractor which I purchased new in 1975, finally had to have the powersteering drive belt and the generator belt replaced because they had stretched too much. Anyway I removed the front end of the tractor, which wasn't easy because I have a loader on the tractor. I had the radiator rebuilt and installed a new thermostat while I had it tore apart. I put the new belts on and tensioned them to tight and the power steering pump started to make some noise. A long story short is that the drive pulley on the pump went away and destroyed the bore of the pulley. The pump seens to be fine. I need to find a new pulley or have this one bored out and a sleeve installed in the center of the pulley. Do you have any Idea what the bore &keyway size is. If not I need to tear the front end down again to get those measurements and mount the rebuilt pulley onto the pump. Any help would be greatly appreciated. I can get at the pump to install the pulley without taking the front end apart again, but I need a new pulley or measurements for the old pulley which I can have rebuilt. Thanks.
