HEAD GASKET/MODEL INFORMATION
JIM HARDIN
09-08-1998 11:00:18
FOLKS; I NEED A HEAD GASKET FOR A 4CYL DIESEL OLIVER TRACTOR. DO NOT HAVE THE MODEL NUMBER. SPECIFICATION NUMBER IS 45-0057, SER # 95-394-519
BORE OF 3.750" DOES SOMEONE KNOW THE MODEL NUMBER OR WHERE TO FIND A HEAD GASKET WITHOUT THE MODEL NUMBER?
Mike R.
09-08-1998 22:52:03
 Re: HEAD GASKET/MODEL INFORMATION in reply to JIM HARDIN, 09-08-1998 11:00:18
: FOLKS;
: I NEED A HEAD GASKET FOR A 4CYL DIESEL OLIVER TRACTOR. DO NOT HAVE THE MODEL NUMBER. SPECIFICATION NUMBER IS 45-0057, SER # 95-394-519
: BORE OF 3.750" DOES SOMEONE KNOW THE MODEL NUMBER OR WHERE TO FIND A HEAD GASKET WITHOUT THE MODEL NUMBER?
Jim I'm not sure if you have a GM engine or a hurcules motor, If its a hurcules motor there should be a tag on the left side of the motor about in the center that will state that it's a hurcules. If its a GM you will see GM stamped on various parts of the engine. A four cylinder GM was used in the 1950 Oliver and the four cylinder Hercules engine was used in the 2050 Oliver. Anyway take you serial number and your Model number to an AGCO White dealer and they should be able to determine the exact model of tractor you have and get you the headgasket you need. In order to find the nearest dealer to you go to www.agco.com then click on white tractor dealers and the instructions will help you to locate the dealer closest to you. GOOD LUCK.
