Super 77 Diesel
Bob
01-13-2000 18:11:03
I'm thinking about buying an Oliver 77 Diesel. Could anyone please give me any information on the cost of parts and how easy it is to work on? Someone told me that diesel engines are harder to work on and the parts are scarce. I don't know if this is true or not because I've never worked on a diesel engine. Thanks
Adam
01-15-2000 13:25:09
 Re: Super 77 Diesel in reply to Bob, 01-13-2000 18:11:03
I have a rebuilt super 77 diesel engine in my 770. I replaced the origional 770 gas engine with it and am very happy with it. I'd say they are easy enuff to work on. The previous posts are correct about the pump and injectors needing professional attn if it has problems. timeing is easy. The rest of it is streight forward and simple. The tractor runs cheap and has real good power I pull a 3-16's plow in 3 rd. It starts well no pony motors or dual fuel systems, and has not given me any trouble in 570 hrs since I got it. I also have a 77 diesel. I will not go back to gas. The benifits of diesel far out way the draw backs when as compaired to gas. The benifits are more reliable, less maintance no plugs coils points ect, Verry fuel effecent, they run better no sputering, better throttal responce, more power and less problems with the fuel. Good luck
highboyford
01-13-2000 19:33:22
Bob the super77 is a good tractor gas or diesel.But if this is your first tractor it will be harder to work on because things are alot different then you are used to.What I am trying to say is at least if you know how to work on a car and trouble-shoot than a gas tractor is no problem,but a diesel tractor of any make is a little more involved.On a gas tractor you could take apart and clean the carb but the same part on a diesel is the injection pump and even old grey haired men send them out to a diesel shop for repair(at starting cost of around $300).Alot of the super tractors are still around and parts really are not that hard to find although engine rebuild parts in mop are a little too high (rebuild kit for a 77diesel at $900).I sugest if you do buy the tractor is to look at becoming a member of the Oliver and Hart Parr collectors Assn.For $20.00 a year you can learn alot plus find alot of good parts leads.They have a half done site where you can down load a sheet to mail in.Overall the supers are easy tractors to work on and Ill even give you some reasons.Number 1 if the clutch is bad you do not have to split the tractor(like other brands)to repair.Number 2 pto is very easy to work on and alot cheaper to fix(than someother sick green tractors)well sorry list has to end because I cant think of anything else that might need to be fixed.
try this
01-13-2000 20:32:06
 Re: Re: Super 77 Diesel in reply to highboyford, 01-13-2000 19:33:22
Link not to good with this yet but this should be the way to get to the page for the club.
Mongo
01-14-2000 11:58:37
 Re: Re: Re: Super 77 Diesel in reply to try this, 01-13-2000 20:32:06
I agree with Highboy. I have had a Super 77 Diesel for several years and it had been abused when I got it. I have had the injector pump rebuilt, put in a new clutch and also did the PTO shaft/clutch. Parts are all available. It is a great tractor to work with and has alot of power for the size. The difference in the diesel is you don't have to run as high of rev's to get the job done like with gas and you have to keep the filters and fluids clean. I have found that the made for diesel motor oils are a better buy despite the higher cost. A normal motor oil for gas engines will leak out of your diesel at every gasket and will need replentished, while I have no leakage while using the diesel oil. Also, never run a diesel dry on fuel. This will cause alot of headaches and problems that are easily avoided. Hope this helps.
Chilvers
06-07-2006 15:22:43
 Re: Re: Re: Re: Super 77 Diesel in reply to Mongo, 01-14-2000 11:58:37
Where were able to rebuild the injector pump I just purchased one that has problems as well?
