S55 Hydraulic Gaskets
J Harris
08-08-2007 06:53:40
Hello everyone! I'm still working on fixing my hydraulics on my Super 55 and think I may have found the problem. I was experiencing a leak, loosing hydraulic fluid in a matter of a couple days. I've narrowed that down to a bad gasket between the hydraulic pan and the top cover of the transmission. For some reason, I was also thinking that there was a gasket between the pan and the transmission housing (bottom, with the pan sandwiched between two gaskets).
I was looking through my I&T Shop Manual and didn't notice this second gasket. Am I correct in thinking that it's unneccessary?
I was also having bad leak down and was assuming it was the cylinder o-ring. I am replacing it this round while I've got everything apart, but I also noticed that I was missing one of the flange gaskets where the hardline mounts through the pan to the control valve. Would this also contribute to my leak-down issue?
I bought a sheet of gasket material and have cut out a replacement for the pan gasket as well as the three flange gaskets. My local NAPA had a whole roll (3-ft wide) that they cut to length and sell by the foot, which came in very handy. By the way, I used a piece of .45 pistol brass and a .308 rifle brass to punch all of the holes for the bolts. Worked like a charm!
Thanks,
Justin
in Indiana
J Harris
08-09-2007 05:23:38
 Re: S55 Hydraulic Gaskets in reply to J Harris, 08-08-2007 06:53:40
Thanks for the replies, guys! Yes, I realized the difference between the two and ended up cutting the two main gaskets as well as the three flange gaskets last night.
I also found a place locally (Borden, IN) that is an old AGCO/Oliver shop that still has TONS of parts and pieces for old Olivers. I ended up picking up another cylinder oring & leather back-up washer as well as new seals for the lift arms. They had absolutely everything you could imagine there (as far as standard stuff goes). Let me know if you need me to look for something. It's a couple of old brothers who run the shop and still do things the old-fashioned way. I'm headed back this after noon to settle up with them on the parts I bought because they didn't have the stuff to take debit/credit cards, and my wife doesn't trust me with more than a couple bucks. ;)
Justin
Super 55
08-09-2007 12:08:21
 Re: S55 Hydraulic Gaskets in reply to J Harris, 08-09-2007 05:23:38
Is that the Wright Brothers Implement Dealer?
J Harris
08-09-2007 12:54:52
 Re: S55 Hydraulic Gaskets in reply to Super 55, 08-09-2007 12:08:21
Sure is! You've heard of them? Talk about a hole in the wall. It's just a little block building on the edge of the highway, but they're loaded with just about any part you'd need for an Oliver. Those old guys sure know their stuff too! I stopped by to look for the parts I needed, and they knew exactly what the part numbers were and where to find them in the shop without looking at anything.
I stopped by again today during lunch (about a 15 min. drive from work) but they are closed on Thursdays (and Sundays). They've got a decent Super 55, two 1550s, and what I think might be a couple Super 77s along with a HUGE White sitting out front. Then there's another 77 or an 88 (I'm not good with anything but the 55s & 550s) sitting on one side with a 550 on the other, and sever models junked out back. I don't believe they have a 55/550 for parts, but who knows what's hiding in the weeds.
Next time I'm down, I'll have to snap a few pictures and post them.
Justin
Super 55
08-08-2007 17:22:15
You realize that both gaskets are not exactly the same. They have different cut outs. Just a word of caution if you are copying one from the other.
Old Ford Mechanic
08-08-2007 15:43:52
Just a word of caution, Check that pan very close.I've seen more than one with a hole rusted through.And don't forget the leather backup behind the o-ring on the cylinder piston.
J Schwiebert
08-08-2007 08:15:17
There is a gasket on each side of the pan. Next make sure you put the cylinder assembly in a press to make sure you have found all your leaks.
J Harris
08-08-2007 09:25:03
 Re: S55 Hydraulic Gaskets in reply to J Schwiebert, 08-08-2007 08:15:17
Thank you, sir! Looks like I'll be headed back to Napa for another sheet of gasket material.
Justin
SW3
08-08-2007 15:25:51
 Re: S55 Hydraulic Gaskets in reply to J Harris, 08-08-2007 09:25:03
Precut gaskets are available at a AGCO dealer. May be more $$ though.
