Oliver 880 Hydro Pump
olrusty70
08-07-2007 17:13:59
I took the hydro pump out of my 880 and surprise, surprise the center plate was cracked. I was only making 400psi at the coupling. Also there is a grove in the main housing where the input shaft runs. Can this be surface ground out as long as I don�t go through the O-ring seat? The grove is only about 0.040 deep. And where is the best place to order a new center plate (new preferred but would use a used one).
super99
08-08-2007 02:27:07
 Re: Oliver 880 Hydro Pump in reply to olrusty70, 08-07-2007 17:13:59
Ad in Oliver Heritage- Fleetline pump parts contact Nick Faessler 608/897/4993 Juda, Wis.
Agparts First 1/866/264/9720
Korves Oliver 618/939/6681
O'brien County Imp 1/800/320/6224
Good place to start, Chris
Super 55
08-07-2007 22:17:09
Check out Attica Hydraulics. They were able to get parts for my Super 55 Vickers pump.
J Schwiebert
08-08-2007 03:19:54
 Re: Oliver 880 Hydro Pump in reply to Super 55, 08-07-2007 22:17:09
You need to remember they cator to industrial hydraulic components in which Vickers pumps are very popular.
