60 clutch noise
putz54143
08-05-2007 20:32:12
makes a growing noise when depress all the way in but other wise works as should just picked it up today
B A Star
08-05-2007 21:11:39
 Re: 60 clutch noise in reply to putz54143, 08-05-2007 20:32:12
The release lever that holds the release bearing is contacting the release levers on the pressure plate.  You need to either put a stop to limit the clutch pedal travel or add addtional free travel.
rrlund
08-06-2007 09:33:57
 Re: 60 clutch noise in reply to B A Star, 08-05-2007 21:11:39
Isn"t there a brass bushing in the center of the flywheel that acts as a pilot bearing? If those get sloppy they will growl and vibrate.
