70 engine swap
sdrewes72
08-05-2007 17:10:32
i have a old oliver 70 with a cracked block and have a perfectly good chevy 350 out of my truck i was woundering what if would take to rig it up or if at all possible and if not its just getting scraped out
e
08-06-2007 20:36:30
 Re: 70 engine swap in reply to sdrewes72, 08-05-2007 17:10:32
I have a 70 block for you if you want. I'm in Southern Wisconsin.
sdrewes72
08-06-2007 18:27:03
anyone have any pictures by chance also what would be the difference with a 60 or a 70
Doug N
08-07-2007 01:34:06
 Re: 70 engine swap in reply to sdrewes72, 08-06-2007 18:27:03
third party image
The 60 is a smaller tractor. Width and length. Someone said about clearence for the starter on a 70. Well forget about the 60. Doug N
rrlund
08-06-2007 09:41:27
I don't think the frame is wide enough for the starter unless you use a bell housing with a reverse starter that comes in from the rear like some of the race cars use. The trick is to rig a stub drive shaft in to the clutch to run to the drive shaft on the tractor. You need a carrier bearing at the rear of the bell housing to hold the stub shaft steady. I have one here that was on a Chevy 6 that was in one that I bought.
Jersey Farm boy
08-06-2007 05:30:27
I have seen oliver 60's with V8 engines but never any 70's
