880 Diesel
pnia
08-03-2007 19:45:46
The motor wants to die. To keep it running I have to push the cold start button all the time and then she runs great for a little while. Does anyone have any ideas what would cause this. Thank you, Phil
paia
08-04-2007 17:21:39
 Re: 880 Diesel in reply to pnia, 08-03-2007 19:45:46
Thanks for the replies. To answer both, I just acquired the tractor and do not know when the fuel system was last serviced. This tractor has a Bosch injector pump.
There is a solinoid/switch mounted in the fuel line at the injector pump which "clicks" when the cold start button is pushed. The tractor starts very good. It will run fine for a little bit and then start to sputter and then die. If the button is held down it never misses a beat. When it starts to sputter and the button is pushed for just a little while it runs fine for a little while. The tractor pulls hard as long as the cold start button is pushed.
This tractor may have been used on a remote irrigation pump. Could the solinoid/switch at the injector pump be a safty switch for the motor.
Thanks, Phil
J Schwiebert
08-04-2007 18:25:04
 Re: 880 Diesel in reply to paia, 08-04-2007 17:21:39
Now you are starting to make sense. Do the gauges have reset buttons as well? That solenoid was added. Buy a set of fuel filters, change the primary filter, bleed it and remove the solenoid and then get back with us. Good Luck!. J.
paia
08-05-2007 17:35:03
 Re: 880 Diesel in reply to J Schwiebert, 08-04-2007 18:25:04
The tractor does have a Murphy switch. The wire from the temp gauge to the switch had a bare spot and was gounding out. Problem solved!! Thanks again, Phil
paia
08-04-2007 20:14:54
Thanks again J. I will remove the solinoid and service the filters. I will let you know how it works out.
I have a couple other questions for you if you do not mind. I grew up around my grandfather's 77 and 88 but this 880 is all new to me.
It has a T/A. Can it be shifted up and/or down on the "fly" without using the clutch. Or should the the clutch be used. The T/A seems to be pretty solid. Do you know what the original weight of the tractor is. Also, there is an electric cord with a plug-in coming out of the hydraulic housing, what is it used for.
Thank you, Phil
J Schwiebert
08-05-2007 05:14:25
 Re: 880 Diesel in reply to paia, 08-04-2007 20:14:54
Answer to the first question: Yes, but don't lug it down too far. Answer to the second question, Not in my head and how is the tractor equipped: wide front what size tires, fluid weights, pressed steel or cast wheels. etc. Third question: It is the cord for the hydralectric sytem which was Oliver system of detent control for the cylinder.
paia
08-05-2007 06:35:33
 Re: 880 Diesel in reply to J Schwiebert, 08-05-2007 05:14:25
The tractor has cast wheels (15.5x38) and a narrow front. It does not have a 3pt or any wheel weights/front end weights.
Again J, thank you very much. Phil
J Schwiebert
08-04-2007 05:55:11
All that does is preheat the air. Does this tractor have a Bosch or Roosa Master fuel system? I would change the fuel filters to elimate that as a problem area. How does it start?
super99
08-04-2007 03:55:21
How long since you changed fuel filters and cleaned air cleaner? That would be the first thing I would try. Chris
