Sickle mower setup
David M
08-01-2007 06:40:46
How close should a sickle mower hold down keep the section to the ledger plate? It seems if I bend the hold down to hold the section right on the ledger there's going to be a lot of drag and noise. I have about .030" clearance now how much closer should I try to get?
Dave Sherburne NY
08-02-2007 09:32:25
 Re: Sickle mower setup in reply to David M, 08-01-2007 06:40:46
Care and repair of farm machinery by John Deere says "SNUG" yes thats the term they use. If they are to
tight, your gonna wind up with something broken.
I would say that if you can slip a piece of paper under them, its about right, a matchbook cover to loose.
old
08-01-2007 10:04:45
They have to be tight real tight. If you can slip a piece of paper between them its to loose for most hay. Yes they make a lot of noise thats just how they work and have worked for 50 plus years
Bob
08-01-2007 08:01:45
Didn't see the previous answer, or didn't like it????
