Just purchased an Oliver 1550 diesel
scottjhall
07-29-2007 11:54:47
My wife and I (yes she gets excited about tractors too) just purchase a good running 1550 diesel, but found an oil leak around the PTO shaft. There is a seal inset there about 1/2 inch and it looks like there is room for a second outter seal and possibly an end-cap.
Anyone out there familiar with this and whether it does have two seals, or I just need to replace the existing seal?
I have an I&T Shop manual on order, but looking to get a jump on fixing this leak.
Also, any leads on where to find parts for this tractor online or dealers in SE Michigan?
Thanks for your help,
Scott
J Schwiebert
07-29-2007 13:16:19
 Re: Just purchased an Oliver 1550 diesel in reply to scottjhall, 07-29-2007 11:54:47
What is your defination of southeast MI? I used to work in Monroe county. Boellners in Maumee next to Toledo can help you with your parts situation. I think you are telling me the seal on the output shaft leakings and it sound like you have the single speed PTO. That seal has been around for a long time. If it was me I would take the gear case off change the oil and inspect the bearingss at the time as well. More questions? J.
scottjhall
07-29-2007 15:20:37
 Re: Just purchased an Oliver 1550 diesel in reply to J Schwiebert, 07-29-2007 13:16:19
Thanks for the info, I am in Monroe County :)
Is that AJ Boellner you are referring to in Maumee?
I will probably wait for the shop manual to arrive before I break into it further. I like your idea of inspecting the bearings and I planned on changing all of the fluids on it before putting it to use.
Thanks again for the possible parts supplier.
J Schwiebert
07-29-2007 16:17:54
 Re: Just purchased an Oliver 1550 diesel in reply to scottjhall, 07-29-2007 15:20:37
That is who I was refering to. He can help you with both parts and service if needed. I worked out at the Dana test track. J.
