Oliver 88 ?
william kurnik
01-11-2000 01:18:16
All,
I recently purchased a Oliver Row Crop tractor. However, I have had some difficulty in determining whether or not it is the 88RC or super 88RC, as the side panels are missing. Any help in identifying (model, year, etc) would be greatly appreciated. Photos available upon request.
I can offer the following info off a aluminum plate on the left side of the dash...numbers reflect "-" as shown on plate.
specification number
28-2608
Serial number
54825-804
Thanks again,
William
william kurnik
01-12-2000 22:54:47
 Re: Oliver 88 ? in reply to william kurnik, 01-11-2000 01:18:16
Thanks to all who posted. I will now be able to order filters and replacement parts.
Dave Neubert
01-11-2000 14:46:59
My ser. # book says its a 1957 super.
highboyford
01-11-2000 17:35:34
 Re: Re: Oliver 88 ? in reply to Dave Neubert, 01-11-2000 14:46:59
Well then it should have green rims and oliver stamped in the fenders.
highboyford
01-11-2000 14:06:48
William i have misplaced my serial number book so I cant help you there.But fastest way I know how to tell the difference between a super and a regular is to look and see if it has mounting pads on the frame.Stand at side of tractor and look at engine compartment, glance down a little look left to right, if it is a super you will see two flat pads, one on your left and another on your right,both will have bolt holes in them used to attach loaders and culitavtors etc.You can go to the bottom of this page and click on oliver photos both a super66 and a plain 66 are pictured(no 88)to help you get a idea.
karl d
01-11-2000 12:34:45
the axel size is a bigger diamter on a supper 88
Scott
01-14-2000 15:56:33
 Re: Re: Oliver 88 ? in reply to karl d, 01-11-2000 12:34:45
The man is right. The super has implement mounting pads along the frame. The regulars don't.
highboyford
01-14-2000 19:31:10
 Re: Re: Re: Oliver 88 ? in reply to Scott, 01-14-2000 15:56:33
Scott Karl is right too but I didnt point the axle size out because the man with the tractor does not have any sizes to compare.How can he tell a super 88 from a 88 by just telling him the axle on a super88 is larger?You could also tell him that the radiator is larger on a super and that the front section of the tin work over the radiator is larger on a super.You could also say that a super has more H.P.Wouldnt help him figure out what he had though.
Scott
01-18-2000 09:48:03
 Re: Re: Re: Re: Oliver 88 ? in reply to highboyford, 01-14-2000 19:31:10
Highboyford , "Good Point"
