Oliver 1450 Clutch Adjustment
Maple Lawn Farm
07-28-2007 16:24:40
I finally have the clutch put back together after replacing stretched yoke bolts. Can anyone tell me the proper torques, spring tensions, and tolerances for this clutch? I didn't find anything in the shop manual.
Thanks!
J Schwiebert
07-29-2007 05:41:34
 Re: Oliver 1450 Clutch Adjustment in reply to Maple Lawn Farms, 07-28-2007 16:24:40
You make no sense in that now you want the specs for the springs when you have the clutch back together. What measurements did you use the set the release levers? What type of shop manual do you have? J.
Maple Lawn Farms
07-29-2007 15:27:35
 Re: Oliver 1450 Clutch Adjustment in reply to J Schwiebert, 07-29-2007 05:41:34
I didn't use any measurements to set the release levers. The mechanic that did the work for me took his best guess. I will be tearing the tractor apart again in another month or 2 for a complete overhaul, and at that time I hope to properly adjust the clutch. I have an Oliver Shop Manual, form 432 524, issued 10-1-67. Is there a special bulletin that Oliver issued just for the clutch specs?
J Schwiebert
07-29-2007 16:51:59
 Re: Oliver 1450 Clutch Adjustment in reply to Maple Lawn Farms, 07-29-2007 15:27:35
Yes there was. I hope you have your parts lined up in advance. J.
Maple Lawn Farms
07-29-2007 17:22:20
 Re: Oliver 1450 Clutch Adjustment in reply to J Schwiebert, 07-29-2007 16:51:59
Do you have that special bulletin that you could send me a copy, or do you know where I can get a copy?
Thanks!
