S55/550 Hyd/Trans Gaskets
J Harris
07-25-2007 06:20:11
Well, it seems like every few months I'm back on the board trying to get my Super 55 straightened back out. My current problem is a leak in hydraulic fluid, which I've narrowed down to the gaskets between the transmission, hydraulic pan, and the top cover (2 gaskets). One of the gaskets looks to be in decent shape, but the other was destroyed.
I made the mistake of trying to use Permatex before understanding the potential problems that it could cause. Luckily, it didn't hold either, and I'm now trying to find another solution or a cheap source for replacement gaskets.
I did speak with one guy who claimed that straight petroleum jelly or grease in place of the gaskets would work. Has anyone tried this?
Any help would be much appreciated. I still haven't fixed my charging system problems, but they are easier to deal with than trying to keep enough oil on hand to run the tractor without letting the pump go dry.
Thanks,
Justin in Indiana
SW3
07-26-2007 06:16:54
 Re: S55/550 Hyd/Trans Gaskets in reply to J Harris, 07-25-2007 06:20:11
See post one page back titled GASKET ADHESIVE OR NOT?
Super 55
07-25-2007 08:57:16
I got my gaskets from AGCO. I can't remember what I paid, but are they too expensive now? I don't think you can get around buying one from them. While you are in there, I would replace the 2 small gaskets from the hydraulic pump adapter. Make sure your reinforcing plates, the curved and staright one, are tight.
J Harris
07-25-2007 09:36:43
 Re: S55/550 Hyd/Trans Gaskets in reply to Super 55, 07-25-2007 08:57:16
Super 55,
Thanks for the reply. I have no idea what the cost of replacement gaskets are/were/or will be. Heck, I wasn't even sure if they were readily available. Kent from TX just sent me an email that O'Brien should have them as well. Guess I'll make a few calls.
Not that I expect them to be overly pricey, but why spend $20/ea for 2 gaskets when there may be a product available for a couple bucks locally that would do the trick!
Thanks again, and good luck w/ your 55. I see that it's coming together (and looking nice too!!).
Justin
