Gasket Adhesive or Not?
Super 55
07-23-2007 14:01:07
When putting the transmission cover back together on a Super 55, the hydraulics cover and the transmission top gaskets. Is it necessary to put an adhesive on the cork gaskets?
Mike (WA)
07-25-2007 08:50:21
 Re: Gasket Adhesive or Not? in reply to Super 55, 07-23-2007 14:01:07
I've always used a light coat of non-hardening Permatex for almost every assembly (except heads), and have never had any problems. NEVER use the type that hardens- its really tough to get off the next time you have to take it apart.
Super 55
07-25-2007 08:58:34
 Re: Gasket Adhesive or Not? in reply to Mike (WA), 07-25-2007 08:50:21
Thanks for the info. I did that. I used the non-harding.
SW3
07-23-2007 16:20:59
I was told by the AGCO mechanic to put it on dry. He said if you use silicone and it squishes out a little on the inside, then a piece breaks off and falls in there, gets into the small ports etc. I don't believe the ones i put back in were cork though, I think they were the black paper type. I belive i use some 'high tack' by loctite to keep them in place. good luck.
Super 55
07-23-2007 16:41:40
 Re: Gasket Adhesive or Not? in reply to SW3, 07-23-2007 16:20:59
Yep.. they are the black paper type.Thanks for the info.
cj in wisconsin
07-23-2007 14:31:00
I dont think you need adhesive, but do not use silicone on cork, it acts like a lube and the gasket will squish out. Learned that one the hard way bout 20 years ago
