Oliver 770 310ci Waukesha engine swap
Jeremys108
07-22-2007 13:02:29
Will a 310ci Waukesha out a Oliver 1850 fit in a Oliver 770? If so what modifications need to made?
schocker
07-26-2007 16:26:20
 Re: Oliver 770 310ci Waukesha engine swap in reply to Jeremys108, 07-22-2007 13:02:29
use an 880 bellhousing cut your radiator out lets off and weld bigger ons on
CRT
07-23-2007 13:38:08
It will fit, be carefull of what diameter flywheel, and clutch you use, the 770 bellhousing is not big enough to fit the large flywheel. Engine mounts will line-up, you will have to get creative with the cooling system if you are going to use the 770 radiator. I put a late model 283 (1655) in an 88 and made everthing work.
