Oliver OC3
Kevin McPhail
07-22-2007 12:11:16
Recently purchased a OC3 crawler to restore,Have done many tractors and this is my first crawler. My question is, were is the serial # located? And where is the best place to get a owners manual,parts manual and I.T manual? Thanks
MikeS55d
07-22-2007 15:24:56
 Re: Oliver OC3 in reply to Kevin McPhail, 07-22-2007 12:11:16
As OLD said, the serial # plate is on the bellhousing just above the right frame rail. Look up the number under "serial numbers" (oliver crawlers) in the column at the left side of this page to get the year it was made.
Zimmerman's has the parts and cletrac.org has history and a forum.
The HG and OC3 are pretty basic like most small wheel tractors but undercarriage parts can be expensive (like most crawlers). Once you start "clinking around" it will be worth it.
old
07-22-2007 12:15:47
Zimmermans will have the manauls you need. Serieal number should be on a plate on the left side under the gas tank if I remember right Been a few years since I sold the one I had. The tag does come off easy so it might not even be there. I still have the manuals for the one I had but they are not for sale since I also still have an HG
