Best oil for a Super Diesel
dep
07-19-2007 19:49:33
Was wondering what I should use for oil in my S77D? This is my first diesel... all the rest of them are gas jobs. Temperature ranges from 30-90 degrees.
Thanks
rrlund
07-20-2007 06:43:34
 Re: Best oil for a Super Diesel in reply to dep, 07-19-2007 19:49:33
I run Kendall Super D3 10-30 in all of mine,tractors,truck...even in the gas engines so I only have to have one on hand.
e
07-20-2007 06:36:43
As long as it has a API rating for diesel engines (I think CH, CJ, CI, etc.), you'll be fine. Oil for gasoline engines does not have the soot control that you need.
I personally run Mobil Delvac 15w-40 and can eat off the inside of my engines since they are so clean. Rotella is a good oil as well.
cj in wisconsin
07-20-2007 05:15:43
I use Rotella 15 40 in all my diesel engines. No complaints and never an oil related failure.
ollie770
07-19-2007 21:03:11
We use Shell Rotella 15W-40 in both of our Super 88 Diesels and have had good luck.
old
07-19-2007 21:02:18
I would run rotela since it made just for diesel engines. Your choice as far as weight.
