Super 55, diesel hydraulic field kit.
Paul Stanley
09-06-1998 23:34:34
I have been having some trouble with my 3 point not lifting with a full load. I was reading in my shop manual that there was a problem with oil returning to the resevoir shot across the top of the oil causing foaming. This was remedied by a field kit which looks like it consisted of a filler tube to raise the opening and a higher location for the breather. Has anyone ever done this or know anything about this problem? I have to do some more reading, but would like to hear from anyone who has done this before or is familiar with the procedure. Thanks.
Dennis2
09-08-1998 09:57:16
 Re: Super 55, diesel hydraulic field kit. in reply to Paul Stanley, 09-06-1998 23:34:34
: I have been having some trouble with my 3 point not lifting with a full load. I was reading in my shop manual that there was a problem with oil returning to the resevoir shot across the top of the oil causing foaming. This was remedied by a field kit which looks like it consisted of a filler tube to raise the opening and a higher location for the breather. Has anyone ever done this or know anything about this problem? I have to do some more reading, but would like to hear from anyone who has done this before or is familiar with the procedure. Thanks.
Could this be caused by the use of a detergent motor oil?
Paul Stanley
09-08-1998 21:20:48
 Re: Re: Super 55, diesel hydraulic field kit. in reply to Dennis2, 09-08-1998 09:57:16
: : I have been having some trouble with my 3 point not lifting with a full load. I was reading in my shop manual that there was a problem with oil returning to the resevoir shot across the top of the oil causing foaming. This was remedied by a field kit which looks like it consisted of a filler tube to raise the opening and a higher location for the breather. Has anyone ever done this or know anything about this problem? I have to do some more reading, but would like to hear from anyone who has done this before or is familiar with the procedure. Thanks.
: Could this be caused by the use of a detergent motor oil?
I don't think so Denis. I had the fluids changed at a shop when I bought the tractor back in February. I think it may be the filter. When I get a chance in the near future, I'll check it out. I don't think that filter was changed. I'll let you know if I am correct.
Dennis2
09-12-1998 13:00:14
 Re: Re: Re: Super 55, diesel hydraulic field kit. in reply to Paul Stanley, 09-08-1998 21:20:48
: : : I have been having some trouble with my 3 point not lifting with a full load. I was reading in my shop manual that there was a problem with oil returning to the resevoir shot across the top of the oil causing foaming. This was remedied by a field kit which looks like it consisted of a filler tube to raise the opening and a higher location for the breather. Has anyone ever done this or know anything about this problem? I have to do some more reading, but would like to hear from anyone who has done this before or is familiar with the procedure. Thanks.
: : Could this be caused by the use of a detergent motor oil?
: I don't think so Denis. I had the fluids changed at a shop when I bought the tractor back in February. I think it may be the filter. When I get a chance in the near future, I'll check it out. I don't think that filter was changed. I'll let you know if I am correct.
The super 55 cannot handle detergent oil in the hydrolics. Most oils these days contain detergent. If the shop guy wasn't aware of this, he may have put detergent motor oil, or something worse in your lift hydrolics. It might be a good idea to drain it and refill with a good grade of 30W non-detergent when you change your filter.
Paul Stanley
09-13-1998 00:10:59
 Re: Re: Re: Re: Super 55, diesel hydraulic field kit. in reply to Dennis2, 09-12-1998 13:00:14
: : : : I have been having some trouble with my 3 point not lifting with a full load. I was reading in my shop manual that there was a problem with oil returning to the resevoir shot across the top of the oil causing foaming. This was remedied by a field kit which looks like it consisted of a filler tube to raise the opening and a higher location for the breather. Has anyone ever done this or know anything about this problem? I have to do some more reading, but would like to hear from anyone who has done this before or is familiar with the procedure. Thanks.
: : : Could this be caused by the use of a detergent motor oil?
: : I don't think so Denis. I had the fluids changed at a shop when I bought the tractor back in February. I think it may be the filter. When I get a chance in the near future, I'll check it out. I don't think that filter was changed. I'll let you know if I am correct.
: The super 55 cannot handle detergent oil in the hydrolics. Most oils these days contain detergent. If the shop guy wasn't aware of this, he may have put detergent motor oil, or something worse in your lift hydrolics. It might be a good idea to drain it and refill with a good grade of 30W non-detergent when you change your filter. : Thanks for the riminder and tip. I will be sure and do that.
Dennis
09-07-1998 11:33:41
: I have been having some trouble with my 3 point not lifting with a full load. I was reading in my shop manual that there was a problem with oil returning to the resevoir shot across the top of the oil causing foaming. This was remedied by a field kit which looks like it consisted of a filler tube to raise the opening and a higher location for the breather. Has anyone ever done this or know anything about this problem? I have to do some more reading, but would like to hear from anyone who has done this before or is familiar with the procedure. Thanks. Call Wright Bro.s at 812-967-3029, if it's been done, they have done it. Dennis
Dennis
09-07-1998 11:31:09
