HELP!! Tractor will Start but Starter won't stop running
George the Trac
07-17-2007 15:41:18
Hi everyone I just refurbished my very old Oliver OC4, and the it starts up fine no problem, but once started the starter itself won"t stop running. I don"t know what i"ve wired wrong - any ideas, suggestions or know where I can see a diagram of how it should be wired correctly? Thanks for any advice and help!!!
Mitch jungert
08-10-2007 12:46:42
 Re: HELP!! Tractor will Start but Starter won't stop runnin in reply to George the Tractor Man, 07-17-2007 15:41:18
Make sure you are using a 6v solenoid not a 12v.
J Schwiebert
07-18-2007 06:38:48
I take it this is a 3 cylinder OC-4? On what terminal of the ignition switch dis you attach the wire that goes either to the starter solenoid (or magnetic swich if a gas) Take a test light and with the engine off and the key on in the run position do you have power on the small terminal of the above name items?
rrlund
07-18-2007 06:36:46
What happens if you unhook the wire to it from the switch and touch a jumper wire to the starter?
Jake R.
07-17-2007 19:00:15
Is your solenoid sticking? I had a Harley Sportster that used to stick the relay all the time.
