Oliver #? (can't find)
Wayne C.
07-17-2007 14:38:21
Having resently purchaced an Industrial Oliver with a loader bucket and a Wain Roy backhoe. The tractor has no identification plates to be found. The loader has a model #778 (built in Ware Mass). It was sold as a 1960's vintage. Being a six cylinder gas engine with a carburetor #TSX-755, and no manual clutch (hydro-drive / 6 gears forward / back). There is a casting on the engine block that dates 1959 of January. I've been told it's a 70, 770,80,880 super of these, how can I tell? Pease help.
J Schwiebert
07-17-2007 15:11:54
 Re: Oliver #? (can't find) in reply to Wayne C., 07-17-2007 14:38:21
The TSX 755 was standard on early 770 tractors. To verify that this is a 770 how about the casting numbers off the block? Is there a place on the dash where the serial number tag was mounted originally? 770 Tractors were built starting in 1958.778 were used on 770 tractors also.
Wayne C.
07-18-2007 12:15:17
 Re: Oliver #? (can't find) in reply to J Schwiebert, 07-17-2007 15:11:54
Thank You J Schwiebert for responding so quickly.
The dash mounted serial number tag (like the radiator logo) has been removed. As far as the engine castings, this is what I found.
185220-E
IMB-100-B
12308
these numbers were on the left side of the block (carburetor / starter side). There is what seems to be a date casted into the cylinder head reading 1-4-59. I hope this helps...Thanx again.
