12v change
oleblu
07-15-2007 17:55:09
Y'all will probably laugh when you read this, but I'm serious. I have a 1950 Oliver 77 gas engine that I want to change to 12v. (The 6v. generator works fine, but I like 12v. as standard on everything.) OK, I'm tight with a buck, so I want to use a GOOD 12v. generator from a junk Wheel Horse lawn tractor. The 12v. generator has it's voltage regulator mounted on it, so it's just get it bolted on, wire and go? WILL THIS WORK or is it folly?
BOb
07-16-2007 18:16:47
 $10.00 10 SI alternator.... in reply to oleblu, 07-15-2007 17:55:09
Get a $10.00 10 SI Delco alternator from an auto recycler. (1975 to 1985 Chevy pickup)
If you don't want to mess with the diode, use an "idiot lamp" with a #194 bulb, or equivalent.
Third Party Image
Carl Oh
07-15-2007 19:48:21
 Re: 12v change in reply to oleblu, 07-15-2007 17:55:09
I dont think it will work very well because the engine in the lawn tractor runs at 3600 rpms and your 77 runs at about 1500 .The LM gen only has 1 field coil and needs the speed to produce any amperage . Go buy a cheap 12 v delco for a GM car and wire it up, you dont need a 1 wire alt just a couple more wires and a regulator
