S55 broken throttle linkage
Homesteader
07-12-2007 15:37:32
Hello all. I"ve got a "54 Oliver S55 I"ve been using for a few years on a little farm I"m trying to build. It"s been a great machine, but the last time I used it the linkage from the throttle lever broke right at the "drum" under the hood on the left side. I can"t move the drum by hand (or with hand tools) to adjust the throttle, and it"s at full bore. To top it off, a buddy of mine looked at it and told me he can"t weld it back together for some reason.
I"m at a loss as to what I should do now.
Any tips, suggestions, help would be very much appreciated.
Thanks!
Bill in SC
(Homesteader)
Kent Tx
07-12-2007 19:44:25
 Re: S55 broken throttle linkage in reply to Homesteader, 07-12-2007 15:37:32
You can get a new one from O'brien County Implement--800-320-6224 & talk to Tom---HTH
Kent
pork
07-12-2007 16:09:05
gas or deisel? ive got one for a deisel and are not sure if its the same as gas. if you mean full rpm as your "full bore" , then you should good be able to unhook at carb or injection pump and reduce rpm by hand to at least move tractor around. ill make sure i have the linkage in the morning when i get to the shop and let you know tomorrow night.
Homesteader
07-12-2007 16:41:14
 Re: S55 broken throttle linkage in reply to pork, 07-12-2007 16:09:05
Thanks Pork. It"s gasoline, and yep, I do mean full throttle. (I"m guessing that I may have pulled the lever a little too hard. Snapped when I was givin" her the gas to get out of a culvert.)
I appreciate you checking to see what you"ve got. You think it"ll work with a gasoline Ollie?
Let me know. Thanks again
