80 Value
NSC
07-12-2007 14:42:48
I have two 80's I inherited, and I have been researching and am finding them to be kind of rare. One is not even the 200th one made. Any idea on the value of a tractor like that in running condition?
Ken L.
07-12-2007 16:22:50
 Re: 80 Value in reply to NSC, 07-12-2007 14:42:48
Give us more info. On steel or rubber,& cond of such. Running, engine loose or tight? Cond of sheet metal. Over all cond. Location. Give all the info that you can and then maybe someone can give you the info your looking for.
NSC
07-13-2007 11:48:40
 Re: 80 Value in reply to Ken L., 07-12-2007 16:22:50
Both of the engines are loose, and the tractors have been stored well. Never frozen, both are on the proper rear rubbers, but I have the original steels for the older one. Sheet metal is in good shape, no side shields for the engine. Over all condition isnt too bad, needs some tlc for sure, but a little engine work and I think they would run and work well for you. That help any?
RAB
07-13-2007 13:56:32
 Re: 80 Value in reply to NSC, 07-13-2007 11:48:40
NSC, They never had side shields on them. A weak point was manifolds and they are available as new castings. A lot(?) dropped valves, but this may only have been a KD engine trait, if stellite exhaust valves were not fitted to the gas engines. Things like RC (wide or narrow) or standard might make a difference to value (desirability), as may the gear ratios fitted. Only the standards, for example, could be fitted with a starter motor. Nice old tractors. I have four.
Regards, RAB
havvey
07-12-2007 14:50:20
80's are scarce in some areas. check ebay and completed autions might get you a ball park.
