Oliver 60 wire problems
Farmall MD
07-11-2007 16:05:22
Was having some wiring trouble with our oliver 60 over the weekend. Went to start it and no go. To make a long story short, finally traced it to the toggle switch on dash. Put another switch in and still nothing, so finally just ran a wire from the battery to the switch.
The hot wire that is supposed to go to the switch comes from the light switch, and from the light switch it comes from the elect box mounted under the hood(Voltage regulator?) Problem is it's a mess under that dash(I know there is not alot of wiring to them, but to me it's a mess) I know nothing about wiring. Would any of you be able to post a wiring diagram for an Oliver 60 row crop, 1948. Thanks, Doug N
Ken L.
07-11-2007 16:30:37
 Re: Oliver 60 wire problems in reply to Farmall MD, 07-11-2007 16:05:22
The power for the ignition should be comming from the ammeter. Sounds like someone did a bunch of rewiring and made a real mess. Send me an email with your address and I will send you the wiring diagram right out of an original 60 owner's manual. I've already copied it and it's very clear and readable.
