Super 55 hyd issue
Jerry Ray
07-11-2007 07:06:36
1954 super 55; Last night my three point lift arms stopped lifting. I had a plaform on that carries two 55 gallon drums of water. It worked fine up until I remove the platform. Now they don't lift up. I checked the oil levels and they are good. The pump is pumping since I run a front blade off the same system and it works good. I have shifted the draft control lever to see if I could get some thing to happen but nothing. I can not hear any oil moving or the pump is not making noise like it is straining to move something. Is their some linkage that has came off? Any suggestion would help. I have not dug out the shop manual yet since it was late last night when this happened. Thanks in advance. Jerry Ray
