Oliver 880 Gears Grind
Skycarp
07-09-2007 18:02:16
I have an Oliver 880, 6 cylinder diesel, with 6 speed trans, no Power-Booster, no Reverse-O-Torc Drive. When I am in neutral with the clutch disengaged, the output shaft continues to turn, not as fast as engine speed, but enough that when shifting into a gear, the transmission grinds, then will go into gear. If I do not reduce the engine speed to idle, the gears grind a lot.
Am I looking at a clutch overhaul soon, or is there a fix for this situation that is short of removing the clutch? I speculate that the pilot bushing is grabbing the output shaft and not wanting to turn loose of it, am I close?
Thanks for any suggestions.
schrocky
07-09-2007 18:34:16
 Re: Oliver 880 Gears Grind in reply to Skycarp, 07-09-2007 18:02:16
Sounds like a clutch problem to me, do you have any free travel on the pedal ? is it all gone ? if it is as simple as a clutch throw out bearing I say fix it before you trash a hard to find and repair tranny
skycarp
07-10-2007 05:58:31
 Re: Oliver 880 Gears Grind in reply to schrocky, 07-09-2007 18:34:16
Well, I have plenty of free play. I had over 1 inch so I adjusted it up to 3/4 inch in hopes that the clutch was not fully disengaging. That did not solve the problem. Not to say that it isn't the clutch though.
old
07-10-2007 12:04:36
 Re: Oliver 880 Gears Grind in reply to skycarp, 07-10-2007 05:58:31
Do you by chance have the wrong oil in the tranny or hyd fluid leaking into the tranny which will thin the oil out. I know on my S88 before I fixed a seal in the hyds I had the same problem because of thin oil so the gears would keep spinning for a very long time
skycarp
07-10-2007 15:57:51
 Re: Oliver 880 Gears Grind in reply to old, 07-10-2007 12:04:36
Well, that is a good suggestion except I can stop the rotation of the output shaft by hand with little effort. Then when I release it the shaft starts to slowly rotate again and increased to match the engine rpm. Seems like the rotation of the flywheel is causing the pressure plate go into a slow rotation and slowly pick up speed to match the rpm's of the engine.
In very low idle, I can shift into gear with only a slight clunk, but if I am up a single notch on the throttle position, then I grind noticablly. The clutch is disengaging fully because I can stop the rotation of the output shaft with little effort.
Hummmmm ...
