Oliver 1265 Lift trouble
Larry Van Slamb
07-07-2007 18:55:21
I have an Oliver 1265 and I can't get the lift arms to work. This tractor is new to me so I am unfamiliar with how the 3 point lift mechanism works. Apparently the arms were lifting for the previous owner. What suggestions do you have?
Marc Smothers
07-08-2007 18:05:42
 Re: Oliver 1265 Lift trouble in reply to Larry Van Slambrook, 07-07-2007 18:55:21
Does your tractor have a remote valve?? First off I would take the return filter apart and clean or replace it. The filter is located up by the pump. Clean it and let us know. I can help you through the valve in back if the filter does not cure it. I just went through the same problem with of our 1365's this spring. Marc
Henry Steinberger
10-15-2007 17:44:07
 Re: Oliver 1265 Lift trouble in reply to Marc Smothers, 07-08-2007 18:05:42
Any luck on getting your 3 point working. I bought a 1265 with the same problem. Thanks.
