Fuel lines For 77 diesel
Scott(NC)
07-07-2007 13:12:39
Can you buy the fuel line from the dealer already made-up with ends on them for the injector and the pump. The one"s on my tractor have small holes in them and I need to replace them. Just wanting to know if I can buy them made-to-fit to save me some time so I can get it running again..Thanks Scott
El Toro
07-07-2007 16:01:32
 Re: Fuel lines For 77 diesel in reply to Scott(NC), 07-07-2007 13:12:39
You may be able to get new fuel lines from Kraftpower at 1-888-925-7238 for your Waukesha engine. There should be a model number on the 194cid engine. You can try Endurancepower.com too at 1-800-467-5545. Hal
J Schwiebert
07-07-2007 17:25:37
 Re: Fuel lines For 77 diesel in reply to El Toro, 07-07-2007 16:01:32
Now just wait a minute here. First of all there are 3 different set of fuel line for a 77 diesel since you did not say if it was a fleetline or a super. Second item remember the Oliver engines used a Lanova combustion chamber and the Waukesha engines used a precup chambewr at that time SO the Injection nozzles are not located the same way in the head so they are not the same between a Waukesha and an Oliver engine.
Scott(NC)
07-07-2007 20:30:16
 Re: Fuel lines For 77 diesel in reply to J Schwiebert, 07-07-2007 17:25:37
Sorry about that it is a fleetline 77 diesel and it has the precup chamber in it ..does that help out more....What else do I need to order the fuel lines ????? ?????
svehll
07-08-2007 02:02:32
 Re: Fuel lines For 77 diesel in reply to Scott(NC), 07-07-2007 20:30:16
I sure have a NEW sets for your tractor. Call me at 512-633-5014
