Super 55 Paint , Brake and Hitch Issues
elcajonfarms
07-06-2007 22:28:33
Questions:
1. What green paint should be used for a 1955 Super 55? Fleetline or something else? Where can you buy it?
2. Has anyone overhauled brakes on these tractors? Aside from the riveted-in dry discs, are there any other parts that should be routinely replaced when ovrhauling the brakes?
3. Where can I buy a drawbar to mount in the 3-point hitch?? Oliver had such a product, and I would like to find one.
4. Most of these tractors had only a 3-point hitch. Can a drawbar be mounted with the 3-point in place (I bought a used drawbar assembly for my tractor, which had only a 3-point hitch, but I"m trying to decide whether to install).
Matt Kane
07-08-2007 16:09:37
 Re: Super 55 Paint , Brake and Hitch Issues in reply to elcajonfarms, 07-06-2007 22:28:33
I pull a brush hog on my 3-point with my drawbar in place. I keep a 1 7/8 ball on my drawbar at all times. I can also plow with a 1 point 3 bottom plow with the drawbar on the tractor. You may be limited on depth with it on, but it does fine for me. The nice thing about the drawbars are you can swing the bar out of the way when attaching a 3pt implement. I do know that maibachs in ohio sells an aftermarket drawbar for the 55 and 550 that doesn"t interfere with the use of pto or 3pt implements. Its around 250.00
With the 3point drawbar you want to be careful if pulling anything having the 3-point too high. I pull a 2 bottom pull plow and 12 foot discs with my drawbar.
icesweeper
07-07-2007 20:55:32
There is a guy in Mich I believe who makes replica type drawbars. Can"t find his name or email, sorry.
I would contact Kent Gordon in Texas. He has done super work for me on parts, he may have one. Email me and I"ll forward it on to him. The stock drawbar works fine with the 3 pt. The only time it might interfere is if you have a PTO type item on the 3 pt and have to lower it down, then the shaft could hit the drawbar, otherwise no problems.
T.R.K.
07-07-2007 06:00:47
When I repaired the brakes on Uncle's Super 55 I just replaced the linings. Of course you clean out all the brake dust and make sure the actuator plates are clean. Do not try to lubricate the balls in the actuators. Just leave them clean and dry. Of course you replace any springs that are broken.
the 5/8" bolts that support the actuator do not need to be extremely tight. Tightening them too much bound up the brakes in the housing on this super 55.
Also, I had to knock the high spots off the linings with a belt sander when I put them in as they were dragging in the case all the time. The high spots seemed to mainly be around the grooves in the linings.
For drawbars, Uncle Henry just used a Ford type drawbar between the lower lift arms. You know, a bar with a row of holes in it.
He also had an aftermarket mounted drawbar for it, but it was never on the tractor while he owned it to my knowledge. I put it on once after I got the tractor, but it interferes with the 3-point lift sway chains.
El Toro
07-07-2007 05:24:04
Here are PPG's paint codes for Oliver tractors and
they can be cross-referenced to Martin Senour, Dupont or Sherwin Williams. Hal
Clover White--8229
Clover White--8805
Oliver Green--45132
Oliver Green--40249
Oliver Green--40812
