Supper 88 engine swap
WV Ike
07-06-2007 21:55:33
I've been thinking about swapping out the old engine in my Super 88 with an engine out of an 1800. I know it's been done but I'm not sure what all I'm going to need to make it all work. Thanks for any help. Does anyone know where I could find a good 1800 engine reasonable.
oleblu
07-08-2007 13:29:05
 Re: Supper 88 engine swap in reply to WV Ike, 07-06-2007 21:55:33
WV Ike, a fella around here bought a tractor like you want to do, 88 with an 1800 engine. It looked good, a bit tight but still a clean job. The air cleaner was hung on the outside of the hood (the only thing I could see that tipped it off as a "repower") and one of the bolt heads on the oil filter housing was trimmed down to make clearance for the steering shaft.
Matt L
07-06-2007 22:35:33
What are you gonna do with ur 88 engine?
WV Ike
07-07-2007 22:27:18
 Re: Supper 88 engine swap in reply to Matt L, 07-06-2007 22:35:33
Well for now I"m just going to keep running it. I either sell it once I find a good 1800 engine, or I"ll eventually overhaul it and put it over in my 770. It"s a good solid engine. Strong compression on all the cylinders. 3 and 4 run 15 pounds higher than the rest. they had 170 pounds the last time I checked, and the others had around 155 pounds. I"m not sure why my HP is only 42 to 50 depending on the weather. If you are interested just let me know and I"ll keep you in mind.
Matt L
07-08-2007 00:51:07
 Re: Supper 88 engine swap in reply to WV Ike, 07-07-2007 22:27:18
Im intrested - I have a super 77 military with a stuck engine that id someday like to fix
WV Ike
07-08-2007 18:36:42
 Re: Supper 88 engine swap in reply to Matt L, 07-08-2007 00:51:07
Well my email is [email protected] if you"d like to drop me a line there with you email I"ll let you know if I"m going to sell it.
