Best 6V Battery
reme p.
07-05-2007 07:40:16
I need a new 6 volt battery and would like to but the best one I can get. I.E. cranking power. Does anyone have any suggestions?
thanks.
Tony Sha
07-08-2007 09:28:06
 Re: Best 6V Battery in reply to reme p., 07-05-2007 07:40:16
I have a Co-op E-3 that always rolled over slowly with the 6 volt battery even when fully charged. I put in an Optima and the cranking speed was much faster. They are expensive but worth every penny.
WV Ike
07-06-2007 21:48:41
You could always go with an 8 volt battery. That"s what I had to do with my HP 70. Even the high cold cranking amp Interstate was not enough. If you go with an 8 volt I would get an 8volt battery charger and charge it every now and then. the old 6volt system won"t quite keep it charged enough. If you have cut out instead of a regulator and it has the high charge position then usually you"re o.k. then. As long as I run my 70 on the high charge I don"t seem to have a problem. If you have any questions I"d be more than willing to help.
flearned
07-05-2007 12:44:07
Interstate makes a 650cca that works good on some of my old olivers. The key to a succesful 6v system is high quality large dia. batt. cables.
Super 55
07-05-2007 07:43:37
A lot of people swear by optima.
