cockshutt 50 hydraulic pump
AndrewJ
07-05-2007 07:00:48
Does anyone know if theres a new hydraulic pump available for these tractors?
P Heisey-Harleysville,PA
07-05-2007 17:07:52
 Re: cockshutt 50 hydraulic pump in reply to AndrewJ, 07-05-2007 07:00:48
AndrewJ,
New pumps are not available.
What is wrong with your pump? I have new parts and good used pumps in stock that may help you.
Phil Heisey 215-256-8651 FAX 215-256-1203
AndrewJ
07-05-2007 20:32:37
 Re: cockshutt 50 hydraulic pump in reply to P Heisey-Harleysville,PA, 07-05-2007 17:07:52
I believe its a PESCO..i think...nothing is actually wrong with my pump im just wondering if there is a replacement for it if it goes.
07-06-2007 01:56:31
 Re: cockshutt 50 hydraulic pump in reply to AndrewJ, 07-05-2007 20:32:37
YES, It is a PESCO.
I can assist you if/when it goes!!! It is really a long-long lasting trouble free pump.
The biggest issue is wearing out the shaft seal and losing the hydraulic oil to the trans/rear end case. I have the seal kits on stock. The yellow hood Deluxe series "50" has a throw away replaceable filter inside the tin cover under the seat. I also have the filter, cover seal, and valve rebuild parts on stock.
J Schwiebert
07-05-2007 18:01:35
Phil: Please refresh my memory. Who made the pump to start with? Thanks J.
07-07-2007 03:07:30
 Re: cockshutt 50 hydraulic pump in reply to J Schwiebert, 07-05-2007 18:01:35
Hi John,
The hydraulic pumps for the COCKSHUTT 30-35-40-50-560-570-570S tractors were built by PESCO.
J Schwiebert
07-05-2007 09:07:44
If now send me an e-mail. I have a plan B.
