Cockshutt #30 with Buda engine
Gayle Phillips
07-02-2007 07:26:05
To whom, I have a cockshutt 30 with a buda engine in it to overhall, can not find out who else used that engine so I can look up and order parts for it. Thank you GP
P Heisey-Harleysville,PA
07-04-2007 09:14:25
 Re: Cockshutt #30 with Buda engine in reply to Gayle Phillips, 07-02-2007 07:26:05
Hi Gayle,
I have all the parts on stock that you will need to overhaul or rebuild your COCKSHUTT 30 engine. The sleeve and piston kits that I have are 3 9/16 compared to 3 7/16 standard bore. It will take the cubes from 153 to 164 and increase 6 horsepower.
You have a 4B153 if it is a gas engine. Be careful not to confuse it with the 4G153 which is the Aillis Chalmers version. Some things are the same and some things are different.
Phil Heisey 215-256-8651 FAX 215-256-1203
leroy in ne
07-03-2007 21:08:30
i believe Allis Chalmers purchased Buda and used the 4-153 engine in forklifts plus other applications as an industrial engine. parts should be available thru industrial equipment suppliers and some auto supply stores such as NAPA
J Schwiebert
07-02-2007 08:32:16
It is a 4B-153 engine. You can get a kit from several sources. I just happen to have a Napa catalog in front of me. Sleeve and Piston set is a 226-1459. It will increase the bore 1/16. They also have bearings and gaskets. I suggest you wait will the bearings till you mike the crank. Valves are also lited. Me: I am not much of a kit man. Tear it down measure it all and then make decisions. Questions? J.
