heavy duty super 88 clutch
b_zrimm
06-30-2007 10:33:35
does anyone know of a heavy duty clutch that will fit a super 88 deisel that has been hopped up. i dont think the stock one is going to hold up. or is there a flywheel and clutch out of something else that will fit and is heavier duty
Cody
07-02-2007 13:13:11
 Re: heavy duty super 88 clutch in reply to b_zrimm, 06-30-2007 10:33:35
An 880 industrial clutch will hold 120hp before it slips. Cheap, available and bolts right up.
L.D.W.
06-30-2007 23:43:55
We can set you up very reasonable with a clutch that will hold 150 plus hp with no problems. Drop a email if interested.
Larry
Kevin Meier
06-30-2007 16:11:01
If you need the 11 inch clutch I can get you a 6 pad disc? Unless you are looking for a heavier spring?
