3pt will not work
o
06-28-2007 17:41:28
no 3pt on 1750 oliver ,i have 2500psi pressure on hyd.,good steering,that 1/2 fine thread bolt that bypasses 3pt is in tight,one remote on right side,left side is pluged off,it does not try to move,can it be the relief on 3pt clyinder in side broke off?,or the linkage on the inside that moves with the arm you move the 3pt. up and down with,it moves good and smooth,any help before i pull the top off ,it is all the way down,thanks
J VICKERD
06-28-2007 17:58:36
 Re: 3pt will not work in reply to o, 06-28-2007 17:41:28
MY 1650 HAD THE SAME PROBLEM, I HOOKED ONTO MY TRIPLE-K, RAISED IT, IT WENT UP UP UP, THEN DOWN DOWN DOWN, JUST LIKE THE KID SONG---TURNS OUT THERE IS A BRASS BLOW OFF INSIDE SCREWED DIRECTLY TO THE INTERNAL CYLINDER. I REPLACED IT AND HAS WORKED GREAT FOR THE LAST 12 YEARS. THE PWR STEERING AND HYDRAULICS WORKED GREAT ALL ALONG, BUT THE 3 PT. WOULDN'T EVEN LIFT ITS OWN ARMS
