80 Oliver ring and pinion
Cody
06-27-2007 19:52:58
Is there any difference between the Ring and Pinions in an 80 Row Crop and a Standard? Wanting to speed it up for tractor rides.
RAB
06-28-2007 09:02:56
 Re: 80 Oliver ring and pinion in reply to Cody, 06-27-2007 19:52:58
What is 'it'? The answer is yes and no - it only depends on whether they are 3- or 4-speeder.
However, there are different gear ratios at least for some if not all.
Do you mean tractor rides as in 'road run', and not towing trailer loads of children?
RAB
Cody
06-28-2007 20:08:11
 Re: 80 Oliver ring and pinion in reply to RAB, 06-28-2007 09:02:56
Yes, road rides. It is a 1938 low tank 80 with a 3speed. Will a 4 speed R/P interchange?
RAB
06-30-2007 03:25:56
 Re: 80 Oliver ring and pinion in reply to Cody, 06-28-2007 20:08:11
Looked in destruction manual - a real 'must have' if you want serious info on these old tractors. It says:
STANDARD ROW CROP AND ROW CROP "80" PRIOR TO SERIAL # 109853
ON 11.25-42
C-1 (regular)..... 4.5
C-2..... ..... ....6.3
C-3..... ..... ....8.0
18-28 AND STANDARD "80" PRIOR TO SERIAL # 80532
on 12.75-24
C-1 (regular)....4.3
C-2..... ..... ..6.1
C-3..... ..... ..7.6
C-10..... ..... .9.4
All top speeds in mph
Later serial #s were 4 speeders.
Two of my Standard 80s have C-42 ratios. They are rated at 13.6mph with 13-26 rubber.
Hope this helps.
Regards, RAB
RAB
06-28-2007 23:27:02
Difference is bevel - straight and spiral.
4 speeders can have various gear sets, as could the 3 speeders. I don't know what the 3 speeders were, but were probably slow and less slow, or more slow. I do see there were choices of C-1, C-2, C-3 and C-10 for those.
They changed in (late?) '38 to the 4 speeder. Yours wouldn't have had the 4-gear box fitted, with top locked off? (never seen it but been told they did this on steel wheeled tractors for safety). Shifting pattern will prolly be different for 3's and 4's.
Regards, RAB
