S-55 Front Axle
RCP
06-26-2007 15:17:29
The front axle on the 55 has a LOT of play, and I suspect the pin is wore out and perhaps the hole through the frame is egged. To get access do I have to pull the radiator? Are there bushings in the frame or the axle? Any suggestions on repair?
JD in da UP
06-29-2007 20:10:38
 Re: S-55 Front Axle in reply to RCP, 06-26-2007 15:17:29
Most likely the pin and the hole throught the axle are bad. I can't remember right now if youu need the radiator out of the way or not. Block up the front end real good and have a torch available to warm things up. A good machine shop should fix things right up.
