550 Diesel Ignition Starter Problem
Gary Houck
06-26-2007 06:49:35
Went to start the tractor which had been running fine. There was a spark in the battery compartment I believe to be under the tray. I removed the tray and all the wiring appeared to be fine. I rebuilt the wiring harnesses anyway and reconnected everything the way it was removed. Still the starter would not engage. I took the starter to have it tested and nothing. I've ordered a new starter and voltage regulator. But what I'm concerned with is if somehow my wiring is wrong for a key start system and not a push button. I've disconnected the two cables to the push button and removed as the push button hasn't function since I got the tractor. If anyone has info on how the ignition key, starter, and voltage regulator should be wired please let me know. Ignition is a 4 pole switch. Wiring is 10ga original colors. Starter and Regulator new.
Mike (WA)
06-29-2007 09:20:16
 Re: 550 Diesel Ignition Starter Problem in reply to Gary Houck, 06-26-2007 06:49:35
As far as I know, the diesel 550's are all key start. You mentioned "cables" and a button- I suspect you are talking about the large button near the key switch- looks like an old fashioned dimmer switch that cars used to have- thats the manifold pre-heater. It has larger wires coming to it, with large terminals.
