sluggish 550 diesel
pork
06-24-2007 14:31:42
ive just restored a 550 deisel with complete engine overhaul. the problem is that the engine seems sluggish to me. mabey this is the nature of the tractor? ive triple checked the injector pump timing to engine. the tractor "pepped up" a bit when i advanced the timing from the factory FP mark on the flywheel to a spot halfway between the FP and the INT marks, but when the thottle is pulled back, it seems to slowly come to high idle as opposed to revving-up really fast. the injectors are new, head has been gone through, injection pump(bosch type) is also new, valve clearance was checked twice. the tractor doesnt have much smoke to speak of. i am lost. could the problem be internal engine timing? a faulty injector pump? injector pressure set to high at factory? energy cells? or a fuel supply problem? is there any way to "turn up" the pump? any help would be appreciated. thanks, pork
ADB-IA
06-25-2007 11:09:24
 Re: sluggish 550 diesel in reply to pork, 06-24-2007 14:31:42
I have an 880 with a Bosch pump. When I got it the governor wouldn't open completely under load. Figured out the governor spring was too stiff. When the high idle speed was correct the spring did not have enough travel to open the governor completely. I put on a weaker spring and now the governor opens properly and it will really blow smoke under load. ADB
Tramway Guy
06-25-2007 06:11:18
It would behave like that if the shutoff cable was too short. It has to be completely slack or you won't get full fuel.
Moody Richardson
06-24-2007 21:16:37
bEFORE YOU GO INTO ENGINE, CHECK OUT THE THROTTLE LINKAGE. Years ago we experienced slippage with the the round linkage with the metal push rod not being tight enough to hold its position in place
jldjld
06-24-2007 17:48:04
The spring on the side of the inj. pump is the governor spring, the arm below it must be very free to move. If it's not then post back with comment.
J Schwiebert
06-24-2007 16:45:01
How does it try to start? How many hours are on the overhaul? What was done to the head? What size sleeves and pistons? How did you time the pump.? Start there. J.
pork
06-25-2007 06:03:31
 Re: sluggish 550 diesel in reply to J Schwiebert, 06-24-2007 16:45:01
the tractor cranks about five to seven seconds before starting. i thought this was normal because ive heard they are not strong starting tractors anyway. there are about five hours on overhaul. i dont know what was done to the head as i bought the tractor in peices and boxes and have been assembling it for over a year.the guy said it had been re-done, and it was plastic wrapped. pistons and sleeves also came in the bunch of stuff i got with the tractor, thy were new and i assume stock size. i timed the pump by rotating engine until FP mark showed up on point in window by flywheel, then looked at inspection hole near pump and remeshed pump gear to line up pionter and notch in gear.when trying to get engine to run better,i moved flywheel first, then remeshed pump gear. the linkages are ok, and govenor works free, however my book doesnt say much about its adjustment. another thing i failed to mention is that the original block was cracked, i found a gas block locally and used it for the rebuild after having it tanked and checked. thanks pork
J Schwiebert
06-25-2007 09:57:50
 Re: sluggish 550 diesel in reply to pork, 06-25-2007 06:03:31
I send you an e-mail Send me a phone number back. I think you have a couple of small problems. I will be gone till Friday at noon. J.
oliverhick
06-24-2007 15:26:28
try playing with the governor
