88 Input Shaft Spline Wear Question
Kerwin
06-24-2007 12:16:27
Hello. In doing some clutch work (see my next post) on my 88 RC, I noticed that the splines on the transmission input shaft are worn. I would say that they are about half worn (the splines are getting thinner).
Does anyone have input on whether it's OK to continue to use as is? Or should the shaft get replaced since I'm working in the vicinity? The tractor is a worker, but not used very hard.
I doubt I'd find a used one in any better condition, so who would sell a (reasonable) replacement? Or can the splines on mine be rebuilt?
Thanks for the help.
AB
06-24-2007 20:14:37
 Re: 88 Input Shaft Spline Wear Question in reply to Kerwin, 06-24-2007 12:16:27
What kind of shape is your coupling in? On my Super 88 the coupling was loose/wore out and thus allowed the clutch shaft to have play in it and then wear on the clutch hub. My input shaft was OK but I replaced the clutch shaft, coupling, pto shaft,clutch hub,pilot bearing, and clutch release bearing.
I got my parts from Jerry Stairs at AgPartsFirst 1-866-264-9720. He also has a website Link
geraldo
06-24-2007 14:30:10
I would have the splines rebuilt.A good machine shop will be able to take care of this for you.
