Oliver 77 tractor
russellbitters
01-06-2000 17:16:52
My oliver 77 motor' keeps dying or bogging or dumping, or whatever you want to call it when it is under load. Is this a govenor problem or what and how can I fix it.
Dick L
01-07-2000 06:29:47
 Re: oliver 77 tractor in reply to russellbitters, 01-06-2000 17:16:52
Brian might be correct but I have had several 77's and still have five and I have not had govener problems. I have had distributor problems with the mechanical advance and this will cause an engine to die under load. Also I have had gas tank clogs that would allow enough gas to run at low engine speeds and not enough to pull a load.
Takeing the gas line off at the carb. and putting low pressure in the tank will let you see if the flow changes by adding pressure. I wrap a rag aroung an air nozzel to keep from building to much pressure in the tank. On tractors that have set around for a long time I have found clogs in the neddle valve that is in the sediment bowl. I have had small particals of dirt in carb inlet as well. I like to try the gas flow first when I have a problem such as yours and then the carb. The move to the more mechincal things. Good luck and dont give up and let us know what you find
Brian
01-06-2000 18:14:22
Russell,
A good place to start is to check the adjustment of the govener. If it is too far out of adjustment it will not maintain you tractors engine speed under load. In order to adjust your govener linkage I would reccomend buying a service manual of some sort. The host of this forum(Yesterday Tractor) sells manuals for Olivers. If you buy a repro of the Oliver Service manual it will cost alot since it includes all models during that era. The OWNERS manual will give you the ajustment proceedure for the govener. The Owners manual are much cheaper.
I hope this helps
Good Luck
Brian
