880 diesel cyl liner protrusion
paul's repair
06-21-2007 20:57:40
rebuilding 880 diesel engine--cleaned block--test fitted liners & have about .005 liner protrusion. spec's call for no more than .004. block is super clean. comments or suggestions????? ?????
B jA Star
06-21-2007 23:44:21
 Re: 880 diesel cyl liner protrusion in reply to paul's repair, 06-21-2007 20:57:40
  Question:  Do you have the sleeves clamped down with four washers and bolts as shown in figure 2-54 in the shop manual?   Without the clamping, you will get an incorrect measurement.
paul's repair
06-22-2007 20:32:40
 Re: 880 diesel cyl liner protrusion in reply to B jA Star, 06-21-2007 23:44:21
thanks for reply. did not have liners clamped. tried it & now have anywhere from .002-.003 over all liners. also measured several places around liners with no deviation. your help is very much appreciated!!!!! !!!!! !!!!
RAB
06-21-2007 22:52:43
You wrote: have about .005
You need to keep to the specs and measure protrusion as per manual, accurately. 'About' in my book is between 4 and 6 thou. Not close enough when max is 4.
RAB
