oliver 550 power steering fluid leak
oliver t griswo
06-18-2007 07:33:02
okay, topped off the power steering resevoir (pump / reservoir mounted on generator) and gave it a go. lots of leaking coming from behind the dash at the steering column or thereabouts. haven't openned it up yet. anyone else been down this road? how big a job is it to diagnose? this is the power steering unit with the cylinders acting on the steering knuckles. thanks much!
HuberOR
06-18-2007 20:05:32
 Re: oliver 550 power steering fluid leak in reply to oliver t griswold, 06-18-2007 07:33:02
I just fixed mine steel line fiting loose 1/8 to 1/4 turn stopped the leak yahoo!!
oliver fan
06-18-2007 07:45:43
You have one of the steel lines leaking. No big deal. Slide your battery to the left so you can see the unit. Then, with the tractor out of gear, start the engine and look for the leak. If you don't see it, turn the wheel back and forth until the front wheels are as far left then as far right as they will go. You will find the line that is leaking.
oliver t griswold
06-18-2007 07:49:54
 Re: oliver 550 power steering fluid leak in reply to oliver fan, 06-18-2007 07:45:43
thanks, i'll give that a look tonight to see if i can confirm that's the issue. being something of a rank novice with this stuff, what's the prescription to fix a leaking steel line typically?
oliver fan
06-18-2007 08:12:46
 Re: oliver 550 power steering fluid leak in reply to oliver t griswold, 06-18-2007 07:49:54
I think the lines are still avalible from AGCO. If you don't have a AGCO or a Massey dealer that can get AGCO parts, you can get steel lines from any auto parts store. The problen with lines from a store is, they will have to be bent to fit in the space provided. The four lines all have a sharp "L" in them and it is kinda hard to bend them without collapsing them. You will see what I mean.
