Oliver 1370 Fiat bolt grade
Hinsperg
06-17-2007 19:06:58
A WHITE Oliver 1370 there are four bolts under the oil that hold the vibration damper housing on. The head of the bolt says "FIAT 120". On of my bolts broke and needs to be replaced. What is the grade of this bolt and the torque this bolt should be installed to?
J Schwiebert
06-18-2007 18:14:51
 Re: Oliver 1370 Fiat bolt grade in reply to Hinsperg, 06-17-2007 19:06:58
First of all the bolt is metric and as you may know the metric system for bolt hardness uses numbers. Maybe your bolt is a 12.0 I would need to look and I am not 100% sure I have that information. J.
