air conditioner prob. on White 2-105
NErancher
06-16-2007 14:50:53
Got the tractor last fall, they said new air conditioner pump. I've never had an air conditioner on a tractor, or had problems with one on a vehicle, so I know nothing about it. I turned it on the first time today, it appears to blow cold air right away (90 out today), but the belt squeals. I didn't run it long, speeding up tractor slightly, much worse, holding it down at idle, better, but loud. The belt is new, and it's tight, I don't think it should be any tighter, it's like they had it, I never touched it yet. It only has one belt. Clutch kicks in/out ok when I turn the fan off/on. What could be the problem? Thanks.
thhill
06-17-2007 20:27:15
 Re: air conditioner prob. on White 2-105 in reply to NErancher, 06-16-2007 14:50:53
This sounds goofy I know but it works on mine.
The alternator belt may be making the sqeal.
When I 1st start mine I only run the fan for about 10 minutes then turn the temp control up
For some reason mine squeals unless I let it run a little while before kicking in the compresor.
I think mine fan motor must draw to much current or something and until it charges for a while It makes the alt belt squeal I know sounds crazy.
Lee W
06-17-2007 05:40:40
Check the fan belt the compressor drives from the water pump pulley.
Bob
06-16-2007 20:45:38
Some possibilities:
1.) Worn belt and/or pullies, causing belt to "bottom" in the pullies and slip.
2.) Overcharge of refrigerant. (BAD for compressor.)
3.) System that wasn't "pumped down" before charging, to remove air.
4.) Clogged condensor, or poor airflow through condensor, causing HIGH "high-side" pressure.
NErancher
06-17-2007 13:23:10
 Re: air conditioner prob. on White 2-105 in reply to Bob, 06-16-2007 20:45:38
Well, I tried it quickly this morning. It is not nearly as bad as yesterday, it's down to a squeak at idle instead of squealing, seems to go away a little above idle now. The belt looks new, like it was just replaced when the pump was, pulley on pump looks brand new, and fan pulley "looks" good. The belt looks like it sits right in the new pully, it's down more in the fan one but looks about like the other belts do.
