losing hydraulic fluid on 1850
back40
06-16-2007 06:40:10
I am losing hydraulic fluid and it is leaking from where axle enters into carrier. What do I need to do?
back40
06-18-2007 16:17:10
 Re: losing hydraulic fluid on 1850 in reply to back40, 06-16-2007 06:40:10
Nope, it is hydraulic. Somehow it is leaking through. Thanks to everyone here.
klf
06-17-2007 20:46:13
That is gear oil, not hydraulic fluid, isn't it?
larry h
06-16-2007 15:18:57
the o rings in the hyd bottom are leaking or the pump has a crack in it letting it bypass
newt924
06-16-2007 18:40:14
 Re: losing hydraulic fluid on 1850 in reply to larry h, 06-16-2007 15:18:57
Just a suggestion that might help. Add a bottle of SealLube to the hyd.oil. It will expand the seal. Lasts for years. Find it at seallube.com
Hope this helps.
